Really Need this answered!!
knucksfirst
Ontario, Canada
OK im going home for the holidays and I need winter tires BAD!! Or ill end p hitting the ditch 100% no 4x4 soo. I found some second hnd tires with rims.. the bolt pattern fits and eveything there just big!! They are 205/60R16.... Is that going to fit in my wheel well with no rubbing??? I have a stock mazda b4000 with no lift. Thanks guys I appreciate it very much.
Toyo observe G-02 Winters. You sure they fit like right now my 1997 b4000 only has 14inch rims... pizza cutters. its a 1997. I just dont really wanna spend the $300 the on the way home they rub and cant steer.
A 205/60r16 is a car tire....I sure as hell hope it will fit.
As long as the offset works, you're all good.
All right, I trust your judgement. Ill go buy them tommorow, ill balance them at school. Thanks I really appreciate it Sasq
I wonder what kind of vehicle the guy had them on
Ill find out and let u no.. i just hope i dont buy them then they rub lol blow $300. cant be doin that im broke
Try before you buy bud....better safe than sorry!
Like I said, there will no issue with the size of the tire...all depends on the rim offset.
What is the size of the tires you have on the truck now?
The tire size I have now is either P225/70R14 or P215/70R14. I just went on Tire size calculator did see what im running, I just dont no if I have the Le base or just the Le. Thanks for this I appreciate.
Well either way...the 205/60r16 is narrower and shorter than your current tires. So it will all depend on the rims they are on.
205's will rub on a mini cooper and thats about it. If your worried about 205's rubbin on a pickup then dont ever plan to buy 31's till you get a 6 inch lift.
