Re-tap vs. clean threads
Clean out the threads or retap?
  • Clean the threads
    Votes: 0 0.0%
  • Re-tap the threads
    Votes: 2 66.7%
  • Neither
    Votes: 0 0.0%
  • Different situations require different methods
    Votes: 1 33.3%
  • I just like Rangers.
    Votes: 0 0.0%
  • Total voters
    3
Li'l Work Truck
Did you turn it off and back on again?
GMRS Radio License
Pendleton
SC - USA
Vehicle
Drive
2WD
2.3 (4 Cylinder)
Total Drop
235/70 R15
Complacemcy is the key by which tyrrany opens many doors.
My MINI required that I retap the threads when installing motor mounts. I thought it was a bit nuts, until I saw what came out of it (hardened loctite). That got me thinking about the Ranger and possibe rust issues/buildup on threads. So, if there's an option, what do you prefer? To be specific, this is for  any bolt hole, not just the motor mounts.
Retap, especially if it’s a bolt that has a torque value.
depends on the situation, if its a normal bolt hole that all it does is hold the fender on, thread chaser all the way but like the above, if it holds an important part on the car then re tap
Tap holes and wire wheel bolts unless it is a rescue mission or something weird, then they get a die.
