- Oct 16, 2007
- Prunedale CA
- Manual
Mine used to do that "idle up and down" trick and fall on it's face a lot when starting out. And yes hills just make thing worse. By rebuilding the carb and changing the "map" (manifold absolute pressure) sensor, most all of that left. Also check and make sure your Idle-air adjustment is good. Mine was stumbling enough to irritate me and I kept adjusting the Idle-air out more and eventually realized that I was going about it backwards. Mine needed about 1 to 1-1/4 turnes out. I would consider checking the float level, though it sounds to me like you are at an RPM level that should be below the float levels time to be playing a part. I recently took my engine out and put a gasket kit on it with the exception of the head gaskets and re-installed it with the rebuilt carb and it runs better now then it has in the 18 years I've had the truck.
Eric
Eric
