Ranger leveling and camber
seh6183
I have a stock 96 ranger 4x4. If I do the 2 inch leveling lift for the front, should I need to get camber plates or have to align the truck? I'm on stock tires and suspension
You should need the adjustable camber bushings to get everything back into spec. :icon_thumby:
make sure u get the adjustable ones, then install them at 0* camber/0* caster, then take the little sheet with u to the allignment shop. they will love you forever because they can see how far its off and have a spec sheet to show em where they need to set it
You will need the adjustable camber bushings.
You can adjust the camber yourself with a cheep magnetic angle gauge two bottle jacks and 20 minutes.
After you set the camber , set the toe in.
