I have an 1988 4x4 short bed 2.3 5 speed that got rearended and bent the frame bad. What year frames will interchange with a 88? Will 83 to 88 work or will some of the 90s models work to? Any information appreciated.
Sorry, but that is incorrect for his 1988 truck. 83 to 97 should work except for the front bumper. There was a change in the mounting of the front bumper around 88, I'm not sure exactly when they added crumple zones to the front frame members. All cab mounting points should be the same. 98 the cab had an additional 3" added to the length. I don't know if that affected the cab mounting points.You are stuck with a 1998 and up frame. That is when they changed it and used that frame until 2011 when they stopped making the Ranger. The earlier front part of the frame is definitely different.
They added 3” to the length of the cab in 98, not 93.Sorry, but that is incorrect for his 1988 truck. 83 to 92 should work except for the front bumper. There was a change in the mounting of the front bumper around 88, I'm not sure exactly when they added crumple zones to the front frame members. All cab mounting points should be the same. I think 93 the cab had an additional 3" added to the length. I don't know if that affected the cab mounting points.
Thanks. Noted and my post changed to reflect your info.They added 3” to the length of the cab in 98, not 93.
So what if I wanted to do a back-half to a 93 ranger using a 98' & up rear frame section? Would the newer frame section slip over the older frame at the crossmember/front leaf spring mount area?
