ranger amp
barrytheblade
I have a 1994 ranger splash with an aftermarket deck but no sound from my speakers ,the amp is not powering on ,anybody know where the amp fuse is ,I checked fuse box and distribution box
did you check the fuse on the back of the radio?
If your running an amp im assuming you ran a power tire from the battery to it? If so then there should be an in-line fuse somewhere along the run between the battery and the amp. Also, my amp has two fuses that are on the side of it.
Factory amp has a signal wire that tells it when to turn on, if you JUST did this install an are trying to figure out where you went wrong, hook that wire up to the blue wire coming out of your new deck. I went ahead and pulled out my factory amp - it's underpowered and useless.
