RaceRangers Build
Your truck has certainly come a long way since I used to be a regular back in 2010. It looks great. Nice work.
Thanks man, ya the progress has really increased since we decided to race it. Hoping it will be linked this may.
Sooooooo... We decided to get crazy
418 ci Windsor making upwards of 500hp
RaceRangers Build
RaceRangers Build
holy shit balls. wow...
and when can I get some of those t-shirts??
Well, we put that beast of a motor in out of desperation to make the Beehive race April 13th. Unfortunately it requires a custom set of headers and the oil pan needs to be changed, which could not be done in time. So looks like we are just going to try and get the heads done and get the 302 running in time to make the race.
Parts keep flowing but it's going to be close.
RaceRangers Build
how much for one of each?
New bell housing since the aluminum one was cracked to hell after Primm.
RaceRangers Build
Just might make the race this weekend
RaceRangers Build
looks good man. specs on the 302?
Read post #1311. And if you can't tell that that is a 302 just by looking at it, you haven't been around Fords enough....:thefinger:
You can tell by the heads/shape of the block. 351's look different. Plus see the white goo around the bottom head bolts? A 302's lower head bolts need thread sealant because they go into the water jackets, a 351's do not.
