RaceRangers Build
I see your still running leafs on the rear, Are you going to four link it with the 9"? I figured with new front arms the droop will lack in the rear. What are the plans for the other truck or did I miss that?
Back before you were on coilovers what coil springs did you run? I'm going to run coils with bypasses up front so I have some tuneablity
I had the eibach coils that came with the Camburg 5.5 kit.
Put the 9" in:
RaceRangers Build
RaceRangers Build
RaceRangers Build
RaceRangers Build
RaceRangers Build
RaceRangers Build
Thank you, gotta get a driveline made then it will be driving again. Can't wait to try the spool and 5.86s. The rear sits at 78" wide.
Thanks guys, So I got headers, intake and BBK throttle body for the 4.0. Hoping with the 5.86s it will be kinda fast. Definately a big dif from the 2.3.
Got a lot done today
- mounted bump stops
- braced engine cage
- valved all shocks
- double sheared and mounted rear shocks
- installed BBK throttle body
-mounted grill and headlights
Almost ready
Believe it or not the valving was .08 Comp and .10 rebound front and rear. Can't believe it handled as well as it did before.
I changed it to:
-Front
Comp- .15
Reb - .10
-Rear
Comp- .12
Reb- .08
- valved all shocks
Almost ready
I changed it to:
-Front
Comp- .15
Reb - .10
-Rear
Comp- .12
Reb- .08
How many bleed screws?
Do you think .08 rebound on the rear would be too much?
