- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Update:
So I replaced pretty much everything in the A/C system except the two coils and pressure cycling switch:
New Visteon FS-6 compressor ($$$)
All new barrier hoses & O-rings (suction hose was $$)
New accumulator/dryer
New red orifice tube
32oz. R-134a + 10 oz. PAG lubricant
To my delight, the system was completely spotless inside when I opened it up (unplugging the compressor clutch coil immediately after the A/C quit working made all the difference here). All I had to do was run some solvent through the coils to flush out the old mineral oil (which also came out nice & clean).
It also turns out... the '90 condenser is a nice large serpentine-flow unit, and works exceptionally well with R-134a. I stuffed some thick foam rubber insulation strips (made for window air conditioners) around the gap between the condenser and the radiator so the fan could pull more air through it.
Definitely was worth fixing here in the hot southwest. Too bad summer's now over though lol. (although it's still been pretty warm lately, so I've managed to get some use out of it
