quick question bout heim joints...help!
RebelAssaultTruk
medford
im in the middle of a d44 sas on my ex. i want to heim the ra ends, i need advice. was looking at jegs heim joints and want to know if they will work...
http://www.jegs.com/webapp/wcs/stor...archTerm=heim+joint&catalogId=10002&N=0&Nty=1
is this heim joint going to work? this is info on it. its got a 3/4 hole and 3/4 threads...
Heavy Duty Economy
Ball: 52100 Steel, Heat Treated, Hard Chrome Plated
Body: Carbon Steel, Zinc Plated, Rolled Threads
Static Pull: 3/4''Size - 18,810 Load Lbs.
heres the link: http://www.jegs.com/i/QA1/122/XML8-10/10002/-1
any help is greatly appreciated..will i be able to get a good heim from jegs based on their selection? if so which one would you guys recommend? im lost on this.
they will work. the zimmerman explorer is using 14000 lb heim joints and they have been fine for years. i'm positive you won't be breaking the 3/4" 19000 lbs heims...
AND GET PICS UP OF YOUR SWAP
thanks man. im gonna order them then. is carbon steel alright though? i was thinking chromoly only...
