Question about 8.8 LSD
BobSacamano
Forum Member
⭐Supporting Member
Brookhaven
MS - USA
Other
2021 Bronco Badlands 2 Door
Vehicle
Drive
2WD
2.3 (4 Cylinder)
Skyjacker Leveling Coils
31x10.5x15
I just bought a 8,8 4.10 LSD rear end for my 96 2WD. The gears and bearings all seem to be good but I am thinking about changing the clutch plates. What is the benefit of adding an extra plate? Also, should I consider getting the carbon fiber plates? I am running 31 inch tires.
Adding to or rearranging the clutch pack order makes them grab harder/slip less. Carbon fiber lasts longer than the traditional friction material.
Having a tighter limited slip is really nice off road if you don't want or need a locker. Can be helpful in road racing applications too. If it's real tight your tires will chirp going around sharp corners.
Yeah, what @Shran said.
Also, some gear oil now comes with limited slip additive so before you add any, check and make sure. The additive makes things slippery so the clutches don’t grab as hard so you don’t want to add more than you need. I’ve come across people who think that you should add extra additive because it will “work better like that” but they obviously don’t understand how any of this works. The harder you want it to grab, the less additive you use. No additive is hard on the clutch material though so you need some.
I use gear oil without an additive and add my own Ford Performance friction modifier, it's better than the environmentally friendlier factory stuff the dealers sell now. It also absolutely reeks.
I'm glad you called it LSD and not a posi. A Posi was the weak kneed GM rear end that kept breaking until the owner swapped in a 9 inch.
So I picked up the rear end today. There is no play at the pinion yolk and if I spin one wheel, the other wheel spins the same direction. Are these good tests that my pinion preload and clutch plates are OK? I have yet to open it up and look at the teeth on the gears.
I don't think you can asses the condition of the clutch plates until you get it under load. Good try though 😁
Congrats on the diff 🍻
The clutch plates are easy to change and fairly cheap, odds are they are shagged. There is a breakaway spec in the repair manual but its ridiculioulsly low.
You can put the carbon fibre FRPP plates in it but you will need to reuse the S spring if it isn't 31 spline 4.10. CF clutch are more, but they will work as well or better than adding plates. Note also they revised the stacking order.
Gear oil without FM is pretty hard to find, i would start there and add additional FM if it made noise. (edit : to clarify, i would start with a good quality oil with FM, then add if needed. I would soak the plates in FM)
Thanks! where would I find the revised stacking order? Revised if using carbon fiber?
The stock stacking order puts steels against steels and frictions against frictions, just stack them in the most logical manner and you'll have a good setup and add as many that fit not the amount that comes in the kit, there's room for at least one more per side than is factory...
There are a few videos on Utube discussing clutch orientation and replacement procedures.
