Quandry.
randallmain
Harrisburg, PA
Hello. I am wondering if a transmission from an '87 Extended cab Ranger will work in an '86 Reg. cab Ranger? both 2.9 engines
Shifter tower
There seems to be a problem with the shifter position. The Extended cab top plate is backwards of the Reg. cab.
they made 2 different transmissions in the 80's, but they should be interchangable you just might have to change the plate on the floor. the difference isn't in the cab as far as i know, i've had quite a few gen 1's
