- Jan 5, 2010
- Automatic
Can anyone tell me what the small gauge wire with a connector that is attached to the negative battery cable is for? This is on a1988 BII. When it is disconnected the engine stops running. I sometime get a flickering or solid battery/charging light on the dashboard. When the light is on solid and this wire is wiggled, the light flickers. I have cleaned this connector and taped it up to keep it solidly connected and prevent moisture intrusion. When I had the charging system tested, no problems found.
Thanks.
Thanks.
