Pulling the engine, what should I do?
I've got a 1991 4.0 4x4 with M5OD sitting in the driveway right now I'm working on for my grandson. It is a leaker! I power washed the engine and now I can see the valve cover gasket leaks so they are getting fixed first. The rear main seal is also leaking but I want to clean up that whole area before I tackle that mess. The rear main seal is $50! Evidently the crankshaft is so highly polished at the rear main that a regular seal won't keep it from leaking so the new seals come with a built in micro sleeve to solve the problem. You might want to start soaking all the nuts and bolts on the trans mount, drive shaft, and anything else you may have to remove to take the transfer case and transmission out with some kind of rust solvent so the job is easier when you decide to do it. Just go slow and map out what you want to do. It's easy to tear stuff apart--the hard part will be putting it back together correctly.
i don't know for a 91, but i can tell for a 94 that you can't take the transmission out without removing the exhaust y-pipe or lifting up the body. Might take that into consideration. I know some people will say it can clear without, but having it done this week teached me that apparently my truck would'nt let it go! Measure everything
Actually...we did, 4wd also. It would have been much easier without the Y pipe, but those bolts in the manifold we took one look at those and said "no way!"
Hey, uh, as I ponder the idea of rebuilding the 4.0 ohv some more,
What's the risk of the heads warping when you pull them off? Also, how well do the cam lobes hold up with good consistent maintenance?
Valves and springs generally ok to reuse?
Sent from my VS988 using Tapatalk
I actually know the answer (I think) to this one! The heads don't Warp when you take them off, they warp if the engine ever overheated, and when you take them in to have the valves reworked they will check, I think it's called "decking"
Camshafts last at a very long time I believe, unless there's something very wrong with the engine like not using oil lol
Wait, you have to oil these things!?..... JK
Awesome, that's good news, thanks for the response.
