- Mar 20, 2008
- Oil City, Pa
- Automatic
Pulling motor/ No oil pressure problem
Hi guys, I recently bought a 85 ranger with a 302 from a 88 thunder bird converted to carb. With a late 70's c4 trans. I had to put new floor pans in it and some other stuff to get it to pass inspections.
The last time it was inspected was 03'
but when i was running it around the block my oil pressure was a bit low sometimes around 5 to 10 but then somedays it would be around 40-50. When i went to change the oil, it was basically like black water.. real thin. So i put a new oil filter on it and some 10w 30 in it. The filter was fram though.
When i first fired it up it sounded smoother then it did with the previous oil. So i check it and the level was good, so i took it for a test drive up the hill. When i got to the top it started ticking so i stopped. When i looked down i seen i had NO oil pressure. this is on an aftermarket gauge. So i babied it back down and parked it. i have a new oil pump and gaskets, but i can't drop the pan with it in the truck. So what is the easiest way to pull the motor? Or may something else be wrong.
Truck also has a 3in body lift.
My thought was that the oil pump could push the thinner stuff, but when i put new oil in it, the pump couldn't push it..
Thanks in advance.
Thanks in advance.
