Psi?
rockin86ranger
Hillbilly Heaven
what psi should each piston be around on a 1986 2.0l ranger. i need a quick answer. thanks
id like to see over 140-150ish.
more important than the actual pressure is the balance between all 4 cylinders. you want to be withing 10PSI or so on all holes....if not then youve got a problem.
