- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Been a while so I guess it's time for an update. Not a lot for real progress, but quite a bit of visual progress.
Got the rust holes patched. As mentioned above, I used fiberglass for the repair. I know its not as good as new metal but it's the best I can do for now. I used a marine grade epoxy resin to it should be sealed better and a lot stronger than the stuff you buy at the parts house. Just gotta go back and apply more rust bullet and that'll be done. Someday I'd like to put in new metal, but this should get me by until then.
Now for the visual progress. Remember those beams I bought from Ranger SVT, well they're now under the front of the truck. Painted them and parts that wouldn't be accessible after install. Just semi-gloss black Rustoleum Professionals from a spray can. I know it's cheap but this ain't gonna be a show truck, and its easy to get and should be easy to touch-up. Got the stock springs in for now, want to see how it sits with the V8 before putting in the drop springs. Still got to do s little more before I can put it back on the ground. The steering box is off the frame so I can paint the area where it mounts. Once I get that done I'll be able to re-install it, put the steering linkage back in, and put the front end back on the ground. Then I''ll be able to start swapping the back ends out.
Still working on figuring out the wiring, I'm beginning to think it's more work than I want to tackle. Once I've got the rear axle swapped done I'll start pulling the explorer apart and seeing what it'll take to get it working. I may end up bailing on installing everything from the Explorer and trim it down to just the engine harness. If I do that I'll probably use a painless harness or the like. Won't get some of the features I wanted, but hey it didn't have them before right.
Now for the few pics I've got.
Tomorrow I will try to get the steering box back in and truck back on the ground.
