Project Rupert: Expedition Build-up
you don't need a duff lift. just get some front leveling coils and some extended rear shackles. You can't run belltech shackles on an explorer cause their different than a ranger's shackles. get a set of copperhead fab shackles, a set of rough country leveling coils, a 2" body lift, some new shocks, get it aligned and call it a day. all this is a lot cheaper than a duff lift and it brings it up just as high. Mixing and matching suspension components isn't bad or dangerous. if you buy anything from duff get their poly bushings. If your gonna put on a body lift you might as well get poly body mounts. you can fit 31s without even lifting it, and with all those mods you can definately fit 32 and 33s. with our current economy and you wanting to run arb's id definitely save where I can.
