Project Hiden System (lots of pics)
all that work and you go with kicker.. lol. the wiring looks great man! and that box is cleeeeaaaan!
Yeah, I love the amp but am already thinking about replacing the sub with a Sundown, but I blew my door speakers so those are my first priority when I get some cash.
Show me more of that EQ up front! That's a nice setup! What's it called and where did you get it? Does it control everything or just the sub or what?
Looks like it came out really well. Good job!
Questions:
How well are the hidden boxes sealed?
Do you think the amps are cooling effectively?
Would you have done anything different now that you've got it all built and set up?
Can I have one?
Thanks
I'll grab a better picture over the weekend, but its a Clarion EQS746 and I picked it up from SonicElectronix. I mounted it by cutting the pocket out of a single din mount and filed the opening till it fit. Yes, it controls the full band, it takes the single input and splits it to front, rear and sub outputs. Sounds great, worth every cent.
Questions:
Can I have one?
The whole box was glued and screwed with a heavy dose of Titebond 2, and seems to be pretty well sealed. Yes even on the hottest days the amps have not overheated. I wired in 2 3 inch fans rated for 28cfm in a push pull setup to force air through the amp rack. The only changes I think I would make is to put a 12 inch sub in instead of a 10,and maybe a port for more output.
