Power Windows are not working.
Just a follow up...
My windows were stuck in the down position because I had a bad switch on the drivers side.
I was able to roll up the windows by using a 12V battery from my JetSki.
The second time I rolled my window up by using the JetSki battery, I think it burned out the motor on the drivers side. The passenger side was fine.
I purchased a new drivers side master switch from someone on Ebay for $10. I purchased a new window motor and arm on Ebay for $62.95. It included free shipping.
I plugged the new motor in to the switch to see if it would work and it does. So I think I burned the motor out when I used the 12V JetSki battery. However, when I hit the switch, it sounds like the motor is trying to run but something may be jamming it. The arm in the door is all rusted, so I decided to just replace it.
Also, as a side note - you can pick up a Fuel Filler Hose from Ebay for about $55. Don't pay the $400 the stealership wants.
I hope someone finds this information useful. Or at least, informative. :)
Well that is good you got it squared away somewhat, I have a question and since you kinda had experience in that area I figure you can help(Or the other guys can help) Last night my driver side window went down and could not come back up. The passenger side window is just fine, it goes up and down no problem, but on the drivers side it seems that the motor is gone but I hear the clicking and dimming of the lights and voltmeter in the cab of my '95. I have already replaced the switches (The driver and passenger ones on the drivers side) Is there another switch I need to replace on the truck?
Thats exactly what happened to me. It started out as my switches going bad. I replaced the switch, but by the time I'd done that - I'd burned out the motor on the drivers side.
So when I'd push on the switch for the drivers window to go up, the lights would dim and the volt meter would jump down pretty low. It wouldn't roll up. the passenger side would work though.
I ended up replacing the motor and the arm. $63 shipped, via Ebay. Works fine now. :)
Make sure that if you're going to order the new part, you get the one for the drivers side. There are left and right side parts.
