XxrangeradrianxX
I ran into a problem with my power steering where it started leaking at the gearbox bottom seal, so I fixed that, then it started leaking in the o ring on the pressure hose. I thought I fixed it but then I look in the reservoir and empty. Anyways, I found the leak in between the reservoir and where it separates, so I found the reservoir online I’m just wondering how to pull it off, is it just pull of the pressure hose and the bottom hose and it’ll pull right off, or is there another way it comes off?
