Hey yall, first post on here. I've got an old 1986 2.9L V6 Ranger w/4 speed auto transmission. It was an old Norfolk Southern railyard car and has a ton of issues, so I'll probably be making quite a few more posts. Pretty much replacing all the sensors across the truck, because they're almost all bad.
So, especially recently, I've had a ton of issues with the vacuum system, including some pretty concerning problems. Gonna list some annoyances first that I need help with, if anyone has any suggestions to fix, please let me know!
1. Since I've owned it, it's run extremely rich. I'm getting like 5MPG city and 22MPG highway, so my best guess is that the fuel pressure regulator is just dumping fuel at all times, regardless of AFR detection. Any tips on changing these out? I've heard you need a special tool to remove the metal quickconnect assembly w/ spring, do y'all have like a part number/amazon link to get one?
2. The heater is ALWAYS on. Is there any way to disconnect it, or will the truck just blow hot until I fix the refrigerant lines? I turn the AC/blower off, and it's still blowing hot.
3. After getting it up to about 25MPH in drive for the first time after starting it, it'll refuse to go any faster, and I have to let off the gas entirely. It'll idle really low for like 5 seconds, dumping fuel way more than normal, then start driving normal again. During this, it smells like raw fuel, so I'm thinking the AFR gets so high it starts choking out until the ECM corrects. Is this a vacuum or a sensor problem?
4. I'm not sure if this is a common occurrence, because I can't really find another instance of this. But, definitely the scariest one. When I start the car, it's a very high idle, putting it in drive makes it idle normal, putting in reverse keeps the idle high. When I put it in reverse, the brake booster stops completely, and the high idle means I'm having to slam my foot to the floor to stop it from creeping. Letting up at all makes it creep backwards. During this, it has a huge hissing sound. Thinking this is vacuum, but unsure if anyone else has experienced this too. During the high idle, brake booster goes, so if the truck starts idling high at a stoplight in drive, the same symptom of high speed creep and no booster happens. It happens sometimes in drive, but every time in reverse.
