Possible damaged suspension components?
heptofite
2.3 EcoBoost
i showed my alignment sheet to a friend, and he said the SAI being different per side by 15 degrees means something is bent, and i tend to agree because my truck pulls to the right even though the alignment otherwise is 'in spec', as shown by the sheet.
what do you think?
Also worth noting, is that the Toe was about half a degree outside of spec before they fixed it.
Wish I could tell yea that all looks like jiberish to me But i'm going to stare at and try to figure it out I usually can.
Both sides are off about the same, I could see if one was way off but...
i talked to a guy and he said typically they are around 15-18 degrees, but that wasn't ranger specific, 15 degrees of difference is pretty extreme either way.
