pls help tire size
lilred_84ranger
Forum Member
Cadiz,ky
hi I currently own an 84 Ford Ranger 2WD i have 14x6 rims i don't really understand tire sizes but I want to put on either 31 or 33-inch tires on a 4inch suspension lift my question is what size
I believe @85_Ranger4x4 runs 33's on his rig.. perhaps he can point you In the right direction. I'm not versed enough in the square trucks to have an idea whatll fit and be functional.
I think the biggest tire you can get in 14" is 30x10
you'll need to get 15" or 16" rims to go bigger
31x10.50R15 General Graber ATx
Mine is a 4wd which sits higher from the start, 3" bodylift and I had to reshape the rear of the front fenders slightly... after I did the D35 swap (slightly wider track than the D28, no idea how either compare to a 2wd)
