- Jan 22, 2009
- Manual
Okay so before I bought my 2003 ford ranger 5 speed a recent record was of the clutch master cylinder being replaced. About a week into owning it, at RANDOM times my first and reverse would not shift and if it did shift it shifted hard. sometimes it would shift smoothly. I took it to a place they told me i had a piece of junk in my hydraulic line and gave it back to me. Worked good for 2 days, then started again. Brought it in, said Master cyl was leaking and they replaced that.
The problem was gone for about 3 weeks then it started again, gradually getting worse. Sometimes now I have to turn the truck off to shift into first or reverse. Im thinking the master is leaking again? Why? Something must cause it to go bad 3 times in 2 months.
I called another place and they said my 1/R shifter fork needed to be replaced. And sometimes it randomly can happen if it gets screwed up.
Thing is, all my gears shift harder when this problem occurs, and 1/r wont shift. Is the messed up fork causing my 2-4 and 3-5 to get out of whack and make them harder to shift?
I'm really confused now at what is going on.. someone please help me out.
I don't want to bring it in to have the master replaced again because first thing is that it shouldnt need to be, and if they replace it i know its gonna happen again. There must be something causing it to be bad? Either that or that isn't even the problem.
Is the shifter fork the problem?
Please help.
Please help.
