Pitman Arm help
the boxes are identical.. i have a 2wd box in my 4x4 only difference is the arms.
Does anyone know if the 2wd arm will fit on a 4wd box? It appears that there is no difference in the steering boxes, but I'm worried that the arm may be different. It looks like the 2wd arm is flat compared to the 4wd arm, and that's exactly what i need to bring my drag link angle up a bit to match the trac bar angle.
Should work fine.
But you will almost certainly need to have the truck realigned when you're done.
