Junk Collector
⭐Supporting Member
Truck of Month
So here's the deal, I'm considering ditching the stock wheels on my '88 DD. I am looking at these wheels:
http://store.summitracing.com/large...s+Roll+Formed+Wheels&img=aeo-50-184520s_w.jpg
They are 15x7 with 2" of backspacing. I will be running 215/75/15 tires, which I already have. Basically I just want to widen my stance a little bit and dress it up a little. I understand that the stock wheels have something like 3.75-4 inches of backspacing so the tires "sticking out" about another 2" on each side would be ideal.
Anybody have pics of something close to this? A side pic and a front or back pic would be ideal.
If you disregard all other advice, be sure to use '"sholdered" lugnuts to compensate for the 5/8" studholes.) I agree that simply extending the tire outward through use of spacers or less backspacing will put more stress on the bearings, etc. The better way is to get a lower profile tire (with the same diameter) on a wider rim. That keeps the center of the tire closer to what you have now. I have a set of 8.5" alum. rims (with 3.75" backspacing) that work good with 255/60/15. That gives you 2" wider tire (with 1/2" less diameter) and the 2" wider stance youre looking for without alot more stress on bearings, etc.
