I was going to just do a sas and a 302 swap but the trany I'm useing bolted to A 460
So here is some of the pictures from start to present
The body comes off
Look how small of an area I had to work with
So I started with a 1974 f100 4x4 frame that had be put together
Now Its time to mark and cut the frame
The first check after the cut
and a lot of work gettin it right
We took the left over part of the frame and cut them to fit inside for strength
Startin to look better
here is the first test fit
here is the test fit with the 38.5s
here it is all welded up
I am making a removable front clip to ease motor swaps and ect.I chopped the top off you know for head room.
Here is some pics of the drivetrain
.oh and just so you all know ......
I HAVE A BRONCO II WITH A BIG BLOCK IN IT
A LOT MORE TO COME!!!!!!!
The body comes off
