- Aug 10, 2008
- city of rain wa
does it missfire at idle, low revs , higher revs?
a mil eliminator or a handheld proggrmamer can turn of the cel. as for passing 96s are eec v (OBDII) they run the test from the diagnostic port. mil eliminators or a tune will help the ecu pass the test. If the motor is runing well and in tune and is mostly stock chances are you will still pass a tail pipe test. I passed tests plentry of times without it once on a chevy 2.8l s10 and on a ford 302. If the motor has an timing issue or fuel problem, vaccum leak, rough idle, worn sensors like o2 you will fail. funny enough the best results ive ever seen on a readout after a test the old 2.8 tbi with only a muffler
