ForOffRoadDriving
i have a 1990 for ranger 2wd and all of a sudden my parking brake started having problems with releasing after being depressed. my truck is a manual so i use the brake all the time and im pretty sure it hasnt siezed up because the lines are only 6-8 months old at the most. i replaced all 3 cables at the same time and also installed all new brake components, axle bearings and seals and brake lines. everything has been working good up until about 2 weeks ago. i adjusted the cable like the manual says because the pedal was travelling farther and farther each time i applied it over the period of about a week, so finally i decided to adjust before i went to work and after i did that it was too hard to push at all. i loosened the cable until it was 1/2 between where i put it and where it was. it still was hard to press and release but i figured the shoes just needed to re seat them sleves and maybe it would work better. well when i went to leave work it wouldnt release and i ended up having to loosen the cable all the way up and then pull the lever and wala it released. is there some kind of catch that the lever has that is maybe worn down? any ideas would be good and i know i should probably just pull it out and look at it and then asess it but im not going to get to it for a few days.
