- Aug 7, 2007
- Northern California
- 1995, 2001, 200
- Automatic
Not taking any side here, but I've worked on a few engines - and I used to be a licensed mechanic - and don't remember seeing oil coming out of an exhaust pipe. I have seen "oily residue" but the likelihood of oil making it to the tail pipe is slim. Try putting drops of oil on the outside of a warmed up tail pie and I'll bet you see smoke and disappearing oil, but then again, I never tried that.
If there is something on the inside of the tail pipe - other than a little residue - rub your finger on it (after the pipe cools) and try to determine what it is. There is a problem with combustion and the fuel, possibly including oil mixed in, but oil being forced all they way through the exhaust system is very unlikely. If you have a working catalytic converter it would be impossible - but the converter will stop working very soon after the problem starts so that remains a remote possibility.
The point is that oil in the exhaust is the last thing to look for, but oil in the combustion chamber may be one of the first places to look AFTER checking the ignition and carburetor.
