oil sending unit
ncsdaonex
i need to know where on the 2.3L engine the oil sending unit is because i would like to tee it off and run oil out of there and back into the valve cover fror the turbo i plan on putting on my motor. I also want to know if this will work and i wasnt sure to put this thread under 4 bangers or forced induction.
The oil pressure sending unit is on the drivers side back corner of the head.
the oil return from the turbo is gravity fed. draining back into your valve cover is going to require you to mount your turbo very high...like outside the hood.
your better off to drill and install a fitting in your oil pan.
