oil pump gasket..does it exist?
85rx7_93ranger
Bemidji, MN
im rebuilding my 2.9 and reusing my old oil pump that i rebuilt..i baught a complete felpro engine gasket set but it does not have a oil pump to block mounting gasket..i work at oreillys and have searched everywhere for a gasket and cannot come up with one. my last resort is to check the ford dealership...can anyone help me out here..does this gasket exist? or did ford use metal to metal for the pump seal?
help asap would be great. thanks guys
mitch
you can make a gasket or use a very light coating of RTV... when i say light coating i mean not enough to squeeze out and flake off which could destroy the engine bearings
Gasket paper and a razor blade... hole punches if you're real fancy.
And, rebuilding a motor but using an old oil pump...? Yeah, no. Get a new one. They wear out too. And they come with new gaskets.
Factory is metal-to-metal.
if you insist on using a sealant use so little that you can actually see through
it, a very thin film
AD
i thought factory is metal to metal but i wanted to make sure, thanks allan...actually its really easy to rebuild oil pumps from these motors. the only reason they wear out is the get grooves in the two matting surfaces where the pump itself turns. machine those grooves out and your good to go
