- Feb 22, 2011
- Mississippi
- 3.0 V6
- Manual
- Total Lift
- N/A
- Total Drop
- N/A
I am doing to oil pressure gauge fix and would like to know where is the oil pressure switch located?
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Where did you find the elbow and SS braided line?It's tight back there. I removed the original switch and replaced it with an elbow fitting and braided steel hose to remote mounted pressure sensor. About the only way I could touch the original location was from below the truck.
Royal PITA
It'll fit. Get a hammer.Yes, behind the passenger side head on the block next to the bell housing
Not sure the PS60 sender will fit in there, may need to add an extension
I don’t recall. Might have ordered from Summit or Jegs or McMaster-Carr.Where did you find the elbow and SS braided line?
I bought a Glowshift oil filter sandwich adaptor from amazon. The quality of the piece was top notch... been on my truck since Aug of 18. Zero issues this far.
I like it... it leaves the factory switch/warning light system untouched. On a 4.0L it left lots of room for a gauge sender and/or mechanical connection.
What thread size did you purchase?
Never mind I figured it out. It is 3/4"-16 Thread.
