- Dec 6, 2009
- maplevalley WA
- Automatic
Either that or if it is pulling too much vacuum if you put your cheek up to the breather tube there should be a slight vacuum at an idle you can`t feel with your finger. if it is not pulling fresh filtered air in with new pcv then it is not keeping up with the blowby. I always change the pcv with my yearly spring tuneup air filter, breather filter, cap and rotor and do the plugs every other year thats the schedule I keep. The pcv will pay for itself in mpg with a few tanks maybe less.
