- Aug 9, 2007
- Sacramento
- Automatic
So I just took my truck to the local AAMCO to have them just look at my truck really quick. I have been having a leak for a few weeks now which I thought was coolant because of the smell when it was going onto my exhaust manifold. Well he hooked up the coolant pressure tester and it holds pressure with no sign of a coolant leak. He said it looks like its oil from the back driver side of my engine. He said it most likely is not the heads, probably just a valve cover. When I did my intake gaskets last year I replaced the valve cover gaskets with FEL-PRO ones. Everything was fine until I washed my engine a few weeks ago. Could for some reason the simple green made a leak in the valve cover. It looks like it is only comming on the driver side towards the back of the motor againts the firewall. I will see if I can check the bolts and make sure they are torqued correctly. I dont think I ever put locktite on them. Should I?
Thanks for your input.
