2.5L ('98-'01) Oil Leak
Jay11
5+ Year Member
Texas
'99 4.0+'98 2.5
1998 2.5 2WD 129k miles
Has an oil leak, front of the engine towards the bottom. It's not dripping but the area is caked with oil wetness and mud. UT vids led me to suspect crankshaft seal needs replaced. Problem is when I search for the part on RA, Amazon, AZ, etc. all are giving me different parts (as in the part itself, not just the part number). Heck I am so confused. Which is the correct part number? Should I also replace the camshaft seal? I will be replacing the radiator due to a leak, TStat, serp. belt, idler, tensioner. Thought with the rad out might as well take care of the oil leak.
I just fell into a trap which may have caught you also. I looked up the timing cover seal, but found out they gave me the aux shaft seal. So that may be why you are getting different seal numbers for a "timing cover seal".
Of course all the rubber gets old on all the seals, you might as well change them all while you are in there.
Looks like a Timken 2955.
It's probably that or the housing that it mounts in, unless it's the O ring for the oil pump that's behind the aux shaft.
I didn't see a timing belt and tensioner in your list but would be worth doing while there
Starting to tackle this. Got the Tstat housing out and here is a close up of the leak. Where is the source of the leak and what should I be ordering to get this leak fixed? Initially I thought leak was lower but this area here has more oil wetness.
Any ideas, suggestions even what to look at for confirmation.
@[B]scotts90ranger[/B]
Getting the entire kit including timing belt and tensioner, etc
If the oil leak is above the thermostat then the only real source is either the cam seal or the cam pulley bolt, both can be tackled easily while doing a timing belt, if you pull the cam pulley off the seal is right there and the bolt just needs some thread sealant (permatex has some good thread sealant, usually in a little thing by the register at autozone or whatever, it's plenty). After putting that back together just let it sit overnight and you should be good to go.
It's either that or the valve cover gasket, I would probably do the above before ripping things apart to do the valve cover gasket, but at this point it's probably leaking too....
I am gonna replace the radiator due to a leak. I just flushed the engine but it needs more flushing. So I decided to add preston rad flush. I am not driving this truck unless its a road test. How long can the rad flush stay in without affecting anything? Specifically I won't be off to get to it until Thursday, flush and install new rad. If it's gotta be out asap then I can drain it on Sunday night. But can it stay until Thursday?
The instructions say run it 45-60 minutes and then drain it out. I would follow the instructions.
Got the engine clean, at least the caked oil grime. Well now it's too clean and can't see any leak sources-guess it needs a little more driving. One thing I noticed is tstat housing bolts were wet with oil when I pulled them. Not sure if it's something.
Oil Leak
BTW what is thing thing covered in aluminum foil (passenger side) and what is the purpose? I might have hit it with a pressure washer and caused a little perforation or may be it's always been like that.
Oil Leak
