Sorry, around here is Michigan. I found one for $150 this morning that had 212K on it and was not working. Umm, how about NO!
It sounds like its cheaper to buy down there and freight it up.
Couple of further questions:
How high does the truck need to be jacked up to wiggle this out?
Does the exhaust have to be removed?
Any gotchya's that dont look obvious before starting?
Does the engine need to be supported or will it rest on the mounts and stay put?
This is how I do it, I run the front wheels up on to a set of wheel ramps, then I jack the back up to where I can get under the truck pretty easy, I'm 6'4" tall and 280 pounds, I have found it easier to unhook the down tubes from the exhaust manifolds, and then also unhook behind the cats, this way when I use my trans jack to hold the trans and remove the cross member, these drop our of the way to where I can use very long extensions and remove the trans bolts, BUT first.
you must remove the starter (be sure to unhook the battery first thing) and then remove the four nuts that hold the flex plate to the TQ, then you can unhook the shifter cable and wires, plus the speed'O cable/wires, then remove the drive shaft, THEN you can remove the bolts that hold the trans to the engine.
almost forgot, you need to unhook the trans cooling lines, before you hook this back up to a "new" trans, blow them out really really good.
after they are all out, remove the dip stick tube, one of the trans bolts hold this in, pull the trans back, lower the jack a little and then wiggle the trans a little, lower the jack some more, cuss it a little, then pull some more till you clear the front frame member, then lower the jack all the way down, then pull the trans out from under the truck.
when it's out, stand up, give it a mean look, give it a little kick, and get something cold to drink.
I can remove one in under 1.5 hours if nothing bad happens, and it isn't burning up hot out side.
Robert
posted from my laptop while downloading movies.
