no running light or tail lights
cutlassranger
i checked the fuses all good but i have no tail or running lights could it be a blown buld that will cause all of those to go out
the is one fuse that runs those
if the fuse is good, then the switch probably went bad.
i hope noty lol i jsut replaced it a week ago
I would start with checking grounds. If they are good I would go under the hood. Under the brake booster is a rectangle plug with 11 or 12 wires going into and 7 or 8 coming out the other side. Pull the plug apart and check for burned connections. The plastic will probobly be melted if they are burned. Look for a brown wire. That should be for the tail lights.
In this pic you can see where the connector got hot and melted the plastic.
