- Apr 27, 2012
- Manual
Ok, I've been bashing my head for 2 days on this, and killing my helping hands trying to get some feel into my brakes. So here's some history to see if I'm missing something.
I bought a 88' Ranger about 3 or 4 months ago, and I found it in non running order, and the brake lines were disconnected. Why? Idk. I got the trucking running good, put dropped Ibeams by djm and bought all new parts mostly.
I've replaced the front hoses, calipers and pads. The rotors seem pretty decent still. No stress cracks or heat. I've also replaced the center rear brake hose.
MC - Now when I picked this thing up, it had no brake booster. The MC was the newer still with the plastic reservoir. But all in all it was hooked up as if it were manual brakes. I've replaced it with the 85' all cast older MC. Switched the line ends to match up to the correct ports.
IE: Main port (closest to the firewall) Front
Secondary port (furthest from firewall) Rear
After bleeding the brakes I have plenty of pressure to the rears. But little to no pressure to the front. I've bleed these brakes till my face has turned blue with anger. Theres no air in the lines either. I've gone as far as disconnect all the front hard lines and distributor box and blow them with brake cleaner then blow all the brake cleaner out with air. Clean as it can be then re bled. Still nothing on the front.
I have no pressure in the pedal and its maxing out. The only time pressure is relieved from the pedal while bleeding is when the rear are bled.
Any and all ideas are welcomed. also I've checked for a proportion valve (seems to be a unicorn) and or rabs and there's no evidence of one ever being there. front and rear are separated from one another too. Theres only a brass T block on the front and a t block on there rear thats connected with the center hose.
I've googled for hours too, you guys are my last hope.
