- Nov 5, 2007
- Manual
1994 4.0 5 speed 4WD Ranger --
I decided to check out an intermittent stumble and hooked up my tester to pull any codes. First I did the KOEO test and got:
522 -- vehicle in gear (it wasn't)
172 -- lean bank #1
173 -- rich bank #1
176 -- lean bank #2
177 -- rich bank #2
So far, so good. Then I drove about 10 miles and turned the motor off. Hooked up the tester and started the motor to do the KOER tests, and got -- nothing. I have checked the Haynes manual and Alldata site to make sure of my connections, and found nothing amiss. This occurs with a scan tool or a VOM; I tried both to make sure. Could this be a PCM problem?
172 -- lean bank #1
173 -- rich bank #1
176 -- lean bank #2
177 -- rich bank #2
