Did you check the egr and make sure it is not leaking internally, are the brakes working properly, do you have a new PCV valve. It sounds like a vacuum leak somewhere. Use a length of vacuum tubing and put one end up to your ear and search around the base of the carb and the nipple on the back of the egr spacer is easy to miss down below the brake hose from the vacuum tree. You will hear a hissing when you get close to a leak it is also good for isolating exhaust leaks also. Glad it is running better find the vacuum leak and you should be set. Make sure to check the timing and adjust the idle air after you find the leak. If your using a 2100 or 2150 carb is the hole plugged for the choke thermostat htere is a fitting or threaded poet on the section that goes down at a 45 degree angle that is a direct vacuum leak also plug the hole or cap the fitting. Some pics would help.
Thanks again. I was thinking I still had a leak somewhere. I tried the old WD-40 trick where you spray it around and listen to the change of engine speed when it gets sucked into the intake but didn't have any luck with that. I will keep messing with it with what time I do have. I work pretty much from daylight to dark during the week and don't have much time to mess with it on the weekend. I really am thankful for all the help with this. I am determined to get it running better. As far as the pics go I have no idea even where to start on how to do that. lol
