- Mar 30, 2019
- Northern California
- Automatic
Well i already ran a new wire but the old wire is still there so i guess i can still test it but the alldatadiy flow chart thing i was following said to test the circuit 325 which is the wire from the pcm to the starter relay. But it said to test the resistance to ground & if it is more than 5ohms to fix the circuit & test for normal operation. The dvom im using just shows 600, 6000, 60k, 600k, 60m, when i tested it at anything less than 60k it would just show 0L or 0.L depending on where the setting is set. which is also what it shows if i dont touch the leads to anything? Before i ran a new wire with the meter set at 60k it was reading smthen like 13.4 but anything under 60k it would just show 0.L? Then after i ran a new wire it shows 0.L on all the settings? So i think there was possibly smthen wrong with that circuit but i still have no crank no communication. My thought was that possibly that wire might have fried the pcm? Now that the wire shows less than 5ohms i can move to the next step in the flow chart but it basically says after checking the trigger wire to the starter to replace the starter solenoid & test for normal operation but the starter is new & good i can get it to crank by jumping the starter relay but truck still doesnt start? So i never even tested that wire but i probably should just to be sure. The next problem is that the next step goes on to have me start testing the clutch pedal position switch which i dont think this truck has since its an automatic?
