no blinkers
PaleBlue90
Boosted (Not Stock)
Aurora Colorado
i went to use my blinker and the flasher fell out, i pulled over and put it back in and now i have no blinkers. dead flasher? it worked fine when i last drove it:fie:
smack the flasher module a few times, they like to stick from time to time
well i put a new flasher in and it worked twice so idk. the hazzards work though. do you mean smack the flasher itself?
just smack the fusebox area, the flasher modules sometimes get stuck. but since u installed a new one and its still now working properly it sounds like it isnt getting the proper voltage to make the flasher function as it should....or it just could be ur turn signal switch
i think its the switch, how hard are they to replace? how expensive are they?
bone yard 20-30 bucks tops. its a 15 minute job for someone who has done it before and a 20-30 minute job for someone who hasent. its all plug and play.
86
edit
make shure you buy the entire assembly from the yard.
