The Fox
- Oct 31, 2008
I think Canon holds the record for pissing off customers with their 1D MKIII AF problem!
And then there is the high failure rate on the new 5D MKII:
http://www.luminous-landscape.com/essays/antarctica-2009-worked.shtml
Well, the 1D AF issue was something that could hit any camera. Canon fixed the issue and people are just nit picking the issue more now.
The article has been discussed many time and every time those are still not controlled situations and outside Canon's rating for the camera use. There was also a 80-400mm nikkor that fell apart.
http://photography-on-the.net/forum/showthread.php?t=645696
Anyways, Nikon still has problems on the D300, out of the 3 I have used the AF response is horrible. Too much lag for me when shooting sports. That and I sent my old F5 to Nikon with the older 80-200mm F2.8 because it would crash the camera when I pressed the DOF preview button. It did it only on this lens, and it was one of the only lenses I used besides the 50mm F1.8. Sent it to them 4 times and every time it came back in just as broken as before. I said screw this and got a used canon EOS-3, and it is much better then the Nikon every was. I just had bad problems as of late with the Nikon gear that I use, but the D3 is one hell of a camera. Nikon has lost a customer and will never be able to make it up unless they give me one of everything they make, then maybe.
Nick
