85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
Looks like you have a good starting point anyway.
A couple things I picked up:
Somebody has put a distributer on it, which is easier to deal with than a mag. Good score on that, it looks different than my brother's though (his has a 90 degree bend in is so the dist cap is vertical. Mine has a mag.
It has a C grill on it, you can see the large hole in the bottom for the front pedistal, I don't know what the two holes in the front would be for. If you want to get another one a B, or a power unit (either stand alone or out of a combine) they will have the same shell with the solid bottom. You will have to put mesh in the power unit shells though. I know this because my brother got his engine out of a pulltype combine. He used the shell, but the combines grille mesh is more elaborate and bolts on. Just fill the holes and spotweld new mesh in it.
Somebody has moved the drawbar back, it usually mounts just to the axle dropboxes.
Do you know what the atachment is for that runs most of the length of the tractor? Two way plow maybe??
If you have any questions about it let me know, I have been pretty much all the way around mine.
