- Feb 8, 2022
- Saint Paul, MN
- Automatic
You guys are making me jealous
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Might find it when looking for something else, especially since you bought a new one. That's been my experience.
you also need a check valve to isolate the tank.I'm not sure what the easiest way would be. It's been a long time since I've messed with one. First, look up specs on the machine and see if it's already built-in. The problem with something manual, is that you would want to actuate it every time the motor stops/starts. Even electric compressors often have unloader valves. It reduces the starting current of the motor by removing the load during startup.
Absolutely.you also need a check valve to isolate the tank.
Oh, I’ve taken to carrying a folding box cutter in my pocket many years ago, got tired of sharpening my pocketknife all the time. I also carry a Leatherman Supertool for the past few years. But my electrical bag should have a utility knife with a hook blade, my general construction hand tool bag should have a utility knife, and my truck tool kits should have a utility knife.I buy those aluminum husky folding box cutters in three packs and scatter them around.
I ended up with two of those. Bought one and it went in my kit at home. Then I was out and the F-150 was acting up and the module tested bad and I didn’t have the tool with me so now the second one I bought lives in the toolbox of the F-150 and the module has behaved since, lolA funny looking small deep socket with a 1/2" hex on the outside, a knurled aluminum spinner knob and a T20 bit on the other side. Had to buy it because my '94 E150 stopped running.
I swear gremlins move my tools around. (for some reason that explanation never worked for homework)That's always my experience. I find it right where I left it.
I love them Roloks, I go through them like candy at work.
I remember work supplying them... I'd get a couple new and take the old home.
I probably have more then I will use in my lifetime.
