It's not even that humid here in western South Dakota and I have issues with water and air tools freezing up. I did a bunch of sanding with a d/a outside a few years ago and it would ice up on a 50 degree day. The end results were way better than using an electric sander but the tool frustration was real.
You should be fine with a smaller compressor and intermittent use. Very rarely am I using a die grinder for even 10 minutes at a time or more. Let the compressor refill & keep going. I have a 60 gallon in my main shop and have run into low air on big painting projects with a HVLP gun. It has a very hard time keeping up with a sandblaster. Everything else is fine though.
Sometimes even really small ones are just fine - for example I have a little 4 gallon DeWalt compressor that I use for nail guns and believe it or not, my drywall texture sprayer. That thing uses a LOT of air but I can shoot a whole hopper before I "run out" of air - the compressor runs constantly - but that little sucker builds pressure FAST. By the time I have another hopper full of mud, the compressor is ready to go again.
Most of the time they advertise 5 or 6 cfm consumption. It's a lie. My wag is they will use 3 to 4 times that in continuous use. That said I don't use air tools continuous. But I have a 18 CFM, a 7cfm, and a little 2.5 CFM compressors, so I can pick and chose or potentially hook them all together.
Yeah, and for what I do, it's fine. I think I had some serious die grinding that ate air and I'd let it fill back up. I like having the option, but pneumatic is so cheap and easy to find, and they don't break, so my guess is I'll end up with a lot of dupes.
Yeah... dupes... I have at least 5 air die grinders, 4 air hammers, and a whole bunch of assorted impacts, ratchets, saws, sanders, etc. A lot of them were very cheap or free. I got a really nice IR extended die grinder because a little rust had seized it up. A big IR needle scaler for $5 because the seller didn't know what it was, two Chicago Pneumatic CP715 zip guns for $10 each at an auction. The list continues. *I* don't use air that much, but I use it enough to keep a stock of cool tools, and they're cheap. But I also have a huge investment in cordless stuff.
Sad thing is I want to buy another air hammer, 'cuz Torque Test Channel said the new Sunex one has almost 2x the power of my CP715's. Sigh. It never ends.
At some point is like collecting trading cards, and that's ok.
I think the only air tool I actually bought from a store was my 1/2" stubby, and that was cheap at HF. The rest are FB marketplace and I have maybe $30 total invested, (as with you, some were free) and I have a nibbler, needler, drills, ratchets impacts... all of it. Most needed a little TLC but once cleaned up, they're basically new.
I bought a new “Stanley” impact gun years ago from Walmart. Take the name off it and it could pass for an IR Classic. Also bought a new IR air ratchet and got some stuff from HF (HVLP gun, air hammer, die grinder) and picked up a couple used air tools over the years.
Got my new cordless set. Did the online registration to bump the warranty from 3 to 5 years. No surprises, tools seem light but solid. Came with a rolling case, it's solid enough. Will take everything through a run this weekend, maybe find an actual project or three.
I like a good balance between air and cordless, air tools are cheap especially second hand... my favorite thing for air tools especially die grinders is an inline regulator or restrictor so I can hold the dang trigger wide open but throttle down so I can take my time with things since I usually have my compressor regulator set at like 120psi since everything works better there (right or wrong, do what works... haven't broken anything yet even with oiling every decade or whenever something doesn't work right). When I was porting the head for my turbo 2.3L that was very nice to have, used the same thing when I ported the 5L heads, use that for painting too... just use a cheap regulator with gauge with two quick connects...
I've got a bunch of Bauer cordless stuff and don't regret any of it, I'm sure there's some I haven't used much but there's some silly things I wouldn't be without like the inflator, work light, stereo, brad nailer is super spiffy... of course half of it was obtained with coupons or open box, oh the workshop blowers are super fantabulous, don't know what I did without it...
new set of eyes and a tap guide.
  • New tools you've bought recently?
I picked up a Lincoln AC225 last weekend for $100. It's in rough shape. I hope it works.
Most likely works. I’d open it up and give it a cleaning and a once-over. I think it was SixtyFiveFord on YouTube that did a thing on fixing those up
Was kinda my thought. I've seen some rough ones. Never seen a bad one.
Nice, long cord and leads and a cart, if I didn't have two stick welders and needed/wanted one that would have been tempting...
Time to get some 3/32" and 1/8" 6011 and 6013 rods and get ready to make stuff... I pretty much only use 6011 but a lot of people like 6013...
Pick up some tapered plugs and connectors so that you can remove the leads from it or use longer ones. I think that’s the best upgrade for those tombstone welders!
I'll probably tape up the bare spots in the leads, make some kind of cover for the back. Maybe clean/paint. If I'm feeling really ambitious it might get a pair of connectors for the leads.
