- Feb 22, 2012
- Manual
I bought a 2000 3.0 V6 Ranger last week because i needed a second vehicle. Truck has just over 200k on it. I did not at the time realize how poorly this thing was maintained. Upon closer inspection at home i learned the head gasket was blown and putting bubbles in the overflow tank. The radiator lookind like it had mud in it, not runny brown water, but thick brown clay. The clutch fluid was so low you could see anything in the reservoir. The transmission fuild was black and smelt burnt.
Let me just say that while i am mechanically inclined, I have very little experience with vehicle maintenance. This has been a learning curve, all be it a very interesting one. Had i realized how bad the truck was i probably would not have bought it. Leason learned! lol
I removed the heads and intake manifold and had them leak checked, trued, and cleaned. I replaced the head gaskets and all the other associated seals.( with the aid of a experienced friend) I have replaced the thermostate and flushed the radiator twice with a flush i bought from the store. Thermostate sensind module (i think thats what it was called, it controlled my guage in the cabin) has also been replaced. Truck doesnt overheat and no more bubbles.
The truck idles rough, and has done so before i replaced the gaskets. It has been kicking out a check engine light, twice know. I had it downloaded and it says cylinder 5 misfire. I have replaced the plugs and gaped them, replaced the wires, and replaced the coil. I also am running a thing of injector cleaner in this tank of gas. What else could cause this issue? Could it be the fuel injector? I hope not because i really don't wanna take the intake off again.
Last problem is the transmission. The truck does not like to go in 2nd gear when shifting from 1rst. Also if you slowly accelerate, the truck shifts from 2nd to 3rd ok. If you are normal/hard accelerating, 3rd will grind. Downshifting from 3rd to 2nd is ok. I mentioned earlier that the clutch res was empty, i filled it up and bled the system using an entire bottle of fluid. The clutch feels good, engages and disengages fine. I also drained the old tranny fluid and refilled it with Royal Purple. The magnet on the bottom plug had some fine metal shavings, but no chunks. Truck is shifting mildly better with new fluid but definitely not where it should be. Are my syncro's going out? If so what would be the most economical route to fix it. Pull-a-part has tranny's for 60 bucks, but you really don't know what your getting. Mechanic down the street said it could cost me 1000 bucks. Ive seen rebuild kits for 150 or so, but i have neither the tools or the know how to do that.
Sorry for the long post, just wanted to make sure i gave as much info as i could. Any help/advice would be greatly appreciated.
