New member needs help
2x2'99
MO
Hello all,
long time stalker first time poster. Great site.
Hope I'm posting in right spot.
Need advice. Got a 1999 2wd 3.0 xlt
I'm wanting to swap out rear axel and springs for:
lower gearing for 33" tires (3.0 w/3.73 - what a dog)
2-3" higher than stock ride height (front end is already done-2" lift springs/a-arms/ball joints/alignment)
Needing recommendations for donor vehicle (model/year/axel code)
**Must be a direct swap
Thanks
Hello all,
Thanks
Welcome, Bro. You will not get 33's under there unless you either cut the fender area alot or add more lift. I am running 33's with a five inch lft and I had plenty of room but then the next summer I added a 3 inch body lift. I only added the BL because I wanted it to sit higher then it was.
Here are some photos After the 5 inch lift:
Here is a shot with the 3 inch BL:
